hux2000's avatar
hux2000
Guide
May 04, 2024
Unable to get R7800 to function in bridge mode
My main router is an R7800 that works flawlessly. I recently bought a second R7800, intending to use it in bridge mode, since I have some wired clients elsewhere in the house. I followed these instructions from the manual:
  • Login to new router and go to ADVANCED > Advanced Setup > Wireless Bridge
  • Select the "Enable Bridge Mode" check box
  • Click the "Setup Bridge Mode Wireless Settings" button and enter the settings of the other router
  • I select the 5 GHz option from the drop-down, enter the SSID of my main router, select "WPA2-PSK [AES]" and enter the wi-fi password of that router
  • I uncheck "Get IP Address Dynamically" and enter a static IP address & subnet mask for the new router, and then the main router IP address as the gateway
  • I click "Apply"
After that, the router reboots. But when it comes back up...no bridge mode. That is, the GUI acts as if it's in bridge mode (various menu items are now disabled, as expected) but it doesn't show up in my wi-fi site survey app and when I connect a client to it via Ethernet, that client has no access to anything. It can't even ping the main router's IP.
It's as if putting it bridge mode somehow disabled its wi-fi radios entirely.
Am I doing something wrong?
  • FURRYe38's avatar
    No, Wireless bridge mode is just that, turns the router into a wireles client that connects to the other routers wifi SSID name. When in wireless bridge mode, the R7800 will not broadcast any wifi signals. Only connects as a client to the host wifi router. Then connect wired devices to the back of the bridged R7800 and get internet signals thru the ethernet ports in back.
    • hux2000's avatar
      hux2000
      Guide
      I know what bridge mode is; I'm not connecting any wireless clients to this router. As I said, when I connect a client to it via Ethernet (meaning, with a cable), that client has no access to anything.
      • FURRYe38's avatar
        Check the bridge mode configuration again. Try Dynamic mode then try Static mode for the configuration. Be sure you set gateway and DNS correctly.
