sanchell's avatar
sanchell
Unable to install update for R7000
Greetings, Netgear Community!   I am using a Nighthawk R7000 route with firmware version R7000-V1.0.11.126_10.2.112.   On the netgear site is says the latest firmware version is R7000-V1.0.11.136...
  • Jumzes's avatar
    Jumzes
    Sep 14, 2022
    the router has administration panel which is accesible at
    routerlogin.net
    or
    routerlogin.com
    under advanced section you will be able to find sub-section to update your firmware manually
    then you download it from netgear website, unpack it and push that unpacked main file through the website mentioned above
    router will update and reboot itself
