neilwar
Dec 05, 2020Tutor
Unable to join 2.4G
I have been using my router for a couple of years with no problem but recently all my 2.4G devices lost connection. I changed the security from WPA-PSK [TKIP] + WPA2-PSK [AES] to just WPA2-PSK ...
michaelkenward
Dec 06, 2020Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
neilwar
Dec 06, 2020Tutor
Thanks for the reply.
FW is V1.0.4.62_10.1.74
I have a Virgin Superhub 3 in modem mode.
hope this helps
Neil
- schumakuDec 06, 2020Guru - Experienced User
If you have an Android mobile (could be an older model starting from Android 6, too) install the WiFi Analyzer (by farproc) e.g. from https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en&gl=US and look into the air if there are the 5 GHz and thr suspect missing 2.4 GHz BSSID on air.
- neilwarDec 06, 2020Tutor
Android? All Apple in this household so, unfortunately, can't use that.
Thanksanyway.
So try https://support.apple.com/en-gb/guide/mac-help/mchlf4de377f of this will unveil information of the wireless bands on air.
- michaelkenwardDec 06, 2020Guru - Experienced User
Are both wifi LEDs showing?
Have you been inside the browser graphical user interface (GUI) to check that it is set to broadcast the 2.4 GHz SSID and that it is turned on?
Have you tried a factory reset on the thing to get you back to the default settings:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
A factory reset is the first thing to try if you have issues, especially with new firmware.
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, you can restore the device to its pre-reset state.
Thank you both, I'm out at the moment but will try tomorrow.
thanks for your replies.
