DerekJames
Nov 12, 2021Aspirant
Unable to join network
I've got a bunch of devices connected to my network and they are ruuning great. I bought a new iPad mini and whwn i try to connect, it says "unable to join network". Since there is no other inducati...
- Nov 12, 2021
Try setting manual channel 1, 6 or 11 on 2.4Ghz
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
DerekJames
Solved by joining one of the 5G radios. Must be something weird with 2.4. For channel, it is set to Auto.
Nov 12, 2021Guru - Experienced User
Enjoy. 📡
