rnovak1624
Mar 27, 2020Aspirant
Unable to log into router C7000
Yesterday it was working fine, but today, when i open up the genie software, the router login window pops up. user name is force to admin which is what i want, but i type in password and press login...
- Apr 01, 2020
There is not a way to "move" it however you can post here with a link to the new post that you have started a new discussion at that location.
However, one thing I would "verify" at this point is that if you return your setup to it's original configuration without the extender will the problem go away or stay.
rnovak1624
A bit more information. when I click on the router settings tab, a login window pops up with information filled in, but the login button is greyed out, the cancel button is blue. cursor spins for several seconds and then wireless settings tab opens, but no information is shown, and a message appears at the top that operation has timed out. This is on a windows PC that has has the genie installed and running fine for at least a year.
