rnovak1624
Mar 27, 2020Aspirant
Unable to log into router C7000
Yesterday it was working fine, but today, when i open up the genie software, the router login window pops up. user name is force to admin which is what i want, but i type in password and press login...
- Apr 01, 2020
There is not a way to "move" it however you can post here with a link to the new post that you have started a new discussion at that location.
However, one thing I would "verify" at this point is that if you return your setup to it's original configuration without the extender will the problem go away or stay.
rnovak1624
Apr 01, 2020Aspirant
Is thre a way to move this to the correct section?
additude
Apr 01, 2020Virtuoso
- rnovak1624Apr 01, 2020Aspirant
Attitude, it looks like you may have solved my problem. I unplugged the extender and genie worked. I then moved the extender farther away from the router, and so far, it's still working. The extender is on another level of the house, was probably 30 feet away from router. now it's more like 45 feet away. Thank you for your help.
- additudeApr 02, 2020Virtuoso
Cool. Is it still working?
A Kudos or Problem Solve is helpfull.
Thanks.
- rnovak1624Apr 02, 2020Aspirant
I checked again this morning, all is working good! thank you for your help!!!
