trader88
Jan 26, 2021Guide
Unable to Login to Netgear Nighthawk App Using iPhone
I am currently unable to login to my Netgear Nighthaw app via my iPhone. Firmware up to date and had already uninstalled/installed Netgear app.v Router is working fine and am able to log-in using m...
- Jan 30, 2021
I was able to fix the issue by doing a factory reset of my Netgear Nighthawk R7960P router.
Here's what I did:
1. Uninstall my Nighthawk app
2. Factory reset of my router
3. Reinstall the Nighthawk app
Hope this helps. Thanks to everyone who responded.
frenchcamp49er
Jan 26, 2021Star
Im getting the same thing, di you get it to work?
- trader88Jan 26, 2021Guide
Negative. It would work for about an hour after I reboot my router (R7960P) but would stop working again after that.
