trader88
Jan 26, 2021Guide
Unable to Login to Netgear Nighthawk App Using iPhone
I am currently unable to login to my Netgear Nighthaw app via my iPhone. Firmware up to date and had already uninstalled/installed Netgear app.v Router is working fine and am able to log-in using m...
- Jan 30, 2021
I was able to fix the issue by doing a factory reset of my Netgear Nighthawk R7960P router.
Here's what I did:
1. Uninstall my Nighthawk app
2. Factory reset of my router
3. Reinstall the Nighthawk app
Hope this helps. Thanks to everyone who responded.
trader88
Jan 30, 2021Guide
Here's what I did:
- frenchcamp49erJan 30, 2021Star
Thanks. Did you reapply the current firmware?
- DingerdiFeb 25, 2021Aspirant
I am having the same problem - unable to login to Netgear Nighthawk App using my iphone. But was unsure about doing a factory reset of my router for fear it would create more problems. By resetting to factory defaults does that create any issues?
- frenchcamp49erFeb 25, 2021Star
I would not do that, I dont think it would help. I be;eive it to be a firmware problem with the router.
- antinodeFeb 25, 2021Guru
> [...] By resetting to factory defaults does that create any issues?
It typically forces you to reconfigure your router. Should be
harmless otherwise.
> I would not do that, I dont think it would help. I be;eive [...]I don't know if it would or not. In such a situation, some folks
would run the experiment.
