trader88
Jan 26, 2021Guide
Unable to Login to Netgear Nighthawk App Using iPhone
I am currently unable to login to my Netgear Nighthaw app via my iPhone. Firmware up to date and had already uninstalled/installed Netgear app.v Router is working fine and am able to log-in using m...
- Jan 30, 2021
I was able to fix the issue by doing a factory reset of my Netgear Nighthawk R7960P router.
Here's what I did:
1. Uninstall my Nighthawk app
2. Factory reset of my router
3. Reinstall the Nighthawk app
Hope this helps. Thanks to everyone who responded.
frenchcamp49er
Jan 30, 2021Star
Thanks. Did you reapply the current firmware?
trader88
Jan 30, 2021Guide
Yes, the firmware updated automatically when I did the factory reset, which was the same firmware that I had.
