JIbagast
Nov 16, 2020Follower
Unable to open any custom ports
Hi, Can anyone assit me with this issue. I used to have a TP-Link router and could open any port. When I upgraded to the Nighthawk R8000P my ISP ip address changed and was not able to ope...
michaelkenward
Nov 17, 2020Guru - Experienced User
Forget about your idea of a "solution".
Start by explaining what the problem is.
What are you trying to achieve? (For example, "I have this router that I want to use?")
What are you doing? ("I have followed the instructions in the manual.")
Where does it go wrong? ("I get this strange error message that says....")
