Delerim
Mar 13, 2019Tutor
Unable to Register R9000 router - Alredy Registered
Hello,
A friend of mine bought a Nighthawk R9000 router so that he can use the time restrctionsfor his kids. Unfortuantely this did not meet his needs and hegate it to me.
The problem is tha...
- Mar 13, 2019
Hi Delerim,
Please send me a message with the following and I can have this looked at.
1. Serial Number
2. Email address device needs to be registered to
~Christian
Delerim
Mar 13, 2019Tutor
Hi Kurt,
Thanks a milion for this, i was told that in order to gain access to the apps for phones you needed the product register.
I have the router up and running and would like to be a proper customer of netgear as i love the product, andi had to buy it off my friend as i wasnt aware of hte transfer ofcourse and its not cheap.
Best Regards,
NIko
schumaku
Mar 13, 2019Guru - Experienced User
Uh - thank you for the reminder. Forgot to mention Netgear seems to have inherited some faux logic in the Apps implying the product owner (warranty) and the other access - another one for Christian_R that alone should allow your product transferred! For the moment, start the configuration with the Web based access from a computer.
- DelerimMar 13, 2019Tutor
Thank you :) if it helps this is a similiar case, whit the only difference that they bought it from an online resell site.
I am perfeclly hapy forfeting the warranty and support so long as i can register it as mine.
- Christian_RMar 13, 2019NETGEAR Employee Retired
Hi Delerim,
1. Serial Number
~Christian
- schumakuMar 13, 2019Guru - Experienced User
Good morning Christian, thank you very much for taking care!
Appreciated,
Christian_R can you please push the problem that a second hand device can't be configured by the Apps (as shown in the QSG) if the device is registered to another user MyNetgear account?TIA,
-Kurt
