Zafar2010
Sep 29, 2017Aspirant
Unable to Register ReadyCLOUD on Nighthawk AC1750 (R6700)
Hello, I am unable to Register my ReadyCLOUD account on my router via the routerlogin.net page. After entering my Netgear account login credentials i am getting the message "This router is regise...
- Dec 17, 2017
This issue was resolved. I had to setup it up in router mode for the ReadyCLOUD to work. Thanks to Netgear support.
JamesGL
Oct 03, 2017NETGEAR Employee Retired
Hi Zafar2010,
What is the firmware version of the router?
You can try to use a different browser or different computer to register.
- Zafar2010Oct 04, 2017AspirantHi the firmware version is V1.1.0.42_1.0.1
I also tried using another browser and got the same result unfortunately.
I even got the same error on my phone browser.- JamesGLOct 06, 2017NETGEAR Employee Retired
Hi Zafar2010,
Can you check the timezone of your router? Make sure it is correct. That's under advanced tab> security> schedule.
- Zafar2010Oct 07, 2017AspirantCorrected the time zone but I'm still getting the issue. Does it have to be setup in a modem mode because i set mines up as a router.
