rodrigues_lds
Aug 31, 2018Guide
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
- Nov 29, 2018
They fix it on versio V1.0.9.58_10.2.58!!!!
rodrigues_lds
Sep 01, 2018Guide
Shadowsports, you will only be able to change the attached device type if QoS is set as ON (Advanced > Setup > QoS > Enable QoS) on your router. Then, you can establish data transmission priorities by setting the device type and its priority as shown in the picture below:
DontBlink
Oct 06, 2018Tutor
I am bumping this insteading of creating a new thread since it isn't too old.
I am having this same problem. Even when I change the names, they revert back and do not apply. This never happened before .34. Is this some how related to the changes made to Dynamic QOS?
Even when I change the names in the Nighthawk app, the names and device types revert back and do not apply.
- Jameson746Oct 06, 2018Tutor
I just updated to V1.0.9.42_10.2.44 on my R7000 and it's still doing the same thing.
Did all of the normal. Hard and factory resets. Tried renaming devices from computer (safari), NetGeini app, Nighthawk app... all same same.
- DontBlinkOct 06, 2018Tutor
Step1: What QOS is showing on Router
Step2: What shows in the QOS screen when editing information. This is a Windows PC:
Step 3: What Shows after editing the information:Step 4: What happens when QOS screen is refreshed:
It reverts back and lists my PC as low priority while I am running MMO in backgroud. Gaming packets should have high precedence.
- rodrigues_ldsOct 07, 2018Guide
That is exactly what is happening with my router! Is there any way we can report it? It is so frustrating!
I hope they fix it as soon as possible.
