rodrigues_lds
Aug 31, 2018Guide
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
- Nov 29, 2018
They fix it on versio V1.0.9.58_10.2.58!!!!
rodrigues_lds
Nov 29, 2018Guide
- Jameson746Nov 30, 2018TutorI’m not seeing V1.0.9.58_10.2.58 as an available update.
- rodrigues_ldsNov 30, 2018Guide
Jameson, that is weird! I saw an update firmware version available three days ago and I updated my router. However, I opened Netgear website today and for some reason they dropped that version. As you can see in Netgear UI, my router has a newer version:
- DarrenMDec 03, 2018Sr. NETGEAR Moderator
there was a issue with that firmware and it was taken down it is suggested to roll back firmware versions if you are experiencing issues.
DarrenM
- irishflDec 04, 2018Initiate
I am still experiencing this issue even after installing firmware V1.0.9.60_10.2.60
Does it make anyone a little nervous that Netgear can't fix a simple device label bug that's been around for months/years? Makes me think their code is spaghetti.
- rodrigues_ldsDec 04, 2018Guide
This is annoying and frustrating! It is not a matter of not changing the device label only but If the router does not recognize the device type, Quality of Service (QoS) will not work at all. I have been waiting for this issue to be fixed for months! I updated my router before NetGear dropped 1.0.9.58_10.2.58 version. In addition, this issue with the device label is messing me up! Since the new release (.60) is not available on the NetGear portal (only through device update firmware function), we can not be sure about the changes they made with this "new version".
