rodrigues_lds
Aug 31, 2018Guide
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
- Nov 29, 2018
They fix it on versio V1.0.9.58_10.2.58!!!!
rodrigues_lds
Nov 29, 2018Guide
Jameson746
Nov 30, 2018Tutor
I’m not seeing V1.0.9.58_10.2.58 as an available update.
- rodrigues_ldsNov 30, 2018Guide
Jameson, that is weird! I saw an update firmware version available three days ago and I updated my router. However, I opened Netgear website today and for some reason they dropped that version. As you can see in Netgear UI, my router has a newer version:
- DarrenMDec 03, 2018Sr. NETGEAR Moderator
there was a issue with that firmware and it was taken down it is suggested to roll back firmware versions if you are experiencing issues.
DarrenM
- Jameson746Dec 03, 2018Tutor
1.0.9.60 was released today. Same problem. Cannot rename or re-class attached devices. Tried all of the different ways to do it.
