rodrigues_lds
Aug 31, 2018Guide
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
- Nov 29, 2018
They fix it on versio V1.0.9.58_10.2.58!!!!
rodrigues_lds
Nov 29, 2018Guide
irishfl
Dec 04, 2018Initiate
I am still experiencing this issue even after installing firmware V1.0.9.60_10.2.60
- irishflDec 04, 2018Initiate
Does it make anyone a little nervous that Netgear can't fix a simple device label bug that's been around for months/years? Makes me think their code is spaghetti.
- rodrigues_ldsDec 04, 2018Guide
This is annoying and frustrating! It is not a matter of not changing the device label only but If the router does not recognize the device type, Quality of Service (QoS) will not work at all. I have been waiting for this issue to be fixed for months! I updated my router before NetGear dropped 1.0.9.58_10.2.58 version. In addition, this issue with the device label is messing me up! Since the new release (.60) is not available on the NetGear portal (only through device update firmware function), we can not be sure about the changes they made with this "new version".
- shamarinDec 04, 2018Virtuoso1.0.9.60 is now available on Netgear portal with changelog. It's the same as 1.0.9.58 with additional fixes to Wi-Fi performance.
