rodrigues_lds
Aug 31, 2018Guide
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
- Nov 29, 2018
They fix it on versio V1.0.9.58_10.2.58!!!!
kjag93
Dec 04, 2018Guide
I managed to get .58 before it was pulled. Didn't work initially but after a full reset with the button on the back of the router the naming issue did seem to be fixed. Updated to .60 and it still seems to be working. Try doing a reset and see if that fixes it.
