rodrigues_lds's avatar
Aug 31, 2018
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
  • rodrigues_lds's avatar
    Nov 29, 2018
    They fix it on versio V1.0.9.58_10.2.58!!!!
