rodrigues_lds
Aug 31, 2018Guide
Unable to rename attached device name
After router update (v1.0.9.34_10.2.36), it is not possible to rename attached devices and its type (mobile, computer, etc) in the administration tab. In some cases, when I select a device in the att...
- Nov 29, 2018
They fix it on versio V1.0.9.58_10.2.58!!!!
rodrigues_lds
Dec 04, 2018Guide
This is annoying and frustrating! It is not a matter of not changing the device label only but If the router does not recognize the device type, Quality of Service (QoS) will not work at all. I have been waiting for this issue to be fixed for months! I updated my router before NetGear dropped 1.0.9.58_10.2.58 version. In addition, this issue with the device label is messing me up! Since the new release (.60) is not available on the NetGear portal (only through device update firmware function), we can not be sure about the changes they made with this "new version".
kjag93
Dec 05, 2018Guide
It's always been kinda hit or miss with automatically recognising device type but with the update we can once again manually rename devices, change the deivce type and the QoS priority and those changes seem to now actually save.
