wifi19
Mar 16, 2021Aspirant
Unable to Reset Router Password- Forwarded to wrong link
Hello, I am trying to reset my admin router password. TheTroubleshooting assistance instructions provided through netgear have not been helpful. Each time I click on: https://www.routerlogin.com/...
wifi19
Apr 05, 2021Aspirant
Hello?
None of the solutions resolved this issue. I am still unable to access my router.
Isn’t there a simpler way to solve this issue? Hasn’t anyone thought these steps are far too complex than what should be needed?
antinode
Apr 05, 2021Guru
> my router.
"None of" _whuch_ "the solutions"? The non-psychics in your audience
might have no idea what you mean.
"unable" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> Isn't there a simpler way to solve this issue? [...]
"simpler" than _what_?
- schumakuApr 05, 2021Guru - Experienced User
Probably answering the simple question from above would give us an idea on how to assist:
" Does "Router" have a model number? Look for "Model" on the product label."
The short cut would be a factory reset, and re-configure the router from scratch - permitting you have all data probably required, eg. in case the ISP requires any authentication.
