AndyPast
Mar 18, 2022Tutor
Unable to route to Internet on R7800 unless DHCP server is on.
I re-IPed my house with a range: 172.25.100.0/24 I changed the IP address on my router to 172.25.100.1 I changed my DHCP server (a pi-hole) to give out addresses between 172.25.100.100 and 17...
- Mar 18, 2022
Well, I fixed it. It a case of the fat fingers. The Pi-Hole default gateway had a comma instead of a period in it.
So, it was DNS and human error.
Mar 19, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
