Cypaw1
Feb 08, 2022Aspirant
Unable to Set Up Nighthawk AC2300
For whatever reason I an unable to set up this router. I have cleared cache and cookies. I have tried multiple browsers. I have tried www.routerlogin.com and .net. I have tried 192.168.1.1 and all of...
Feb 08, 2022Guru - Experienced User
You have the R7000P?
Do you have it connected to a modem/gateway?
If so, disconnect it.
Also, try setting it up using a hardwired connection and make sure to be plugging into a lan port and not a wan port.
Another thing to check is make sure you don't have a vpn on.
Or using a virus protection (i've seen someones bitdefender cause issues)
Another question, does it ask you the login password info at all?
