love_cisco
Jun 03, 2017Tutor
unable to setup parental controls via netgear genie
Hi, I just bought the nighthawk R8000 route and want to setup the parental controls via netgear genie. But it stopped at the checing router firmware page. I can access my R8000 via web page. her...
- Jun 06, 2017
Hi,
I got it working now after power reset the netgear route.
thanks
ElaineM
Jun 05, 2017NETGEAR Employee Retired
Welcome to the community, love_cisco
I do not encounter any problem.
Make sure that your computer is connected to the NETGEAR router.
If it persists, reset and reconfigure the router.
love_cisco
Jun 06, 2017Tutor
Hi,
thanks
- ElaineMJun 06, 2017NETGEAR Employee Retired
Thank you for the update.
- JaiderGatorJun 25, 2017Aspirant
This has not been resolved. You have to constantly reboot the router to access the parental control. After you reboot, it only works once then it stops working.
This is also true for the Genie, it works one and then it states that it lost connection to the router or the IPV6 in inable, which in my case IPV6 is off.
When is a new firmware going to be provided correcting this two issues???
- ElaineMJun 27, 2017NETGEAR Employee Retired
Reflashing the firmware should have corrected it. If not, then sounds like you have a defective unit.
Another thing to try is to downgrade the firmware of the router and verify if you'll get the same problem.
