DMac11
Mar 14, 2019Aspirant
Unable to Un-Register R7100LG Router from ReadyCloud
Stuck in a bit of a loop.
Due to my USB device's (1TB Samsung portable HD) continually disappearing and then re-appearing in ReadyCLOUD I un-registered my router from within my ReadyCLOUD acc...
- Mar 24, 2019
Issue solved by Netgear Support. Unit being RMA'd.
DMac11
Mar 17, 2019Aspirant
Bump!
A picture paints a thousand words:
I have un-registered my router on the ReadyCLOUD account and now need to log into my router to register it.
But when I go to the router to register it, as you can see below it is already registered to my ReadyCLOUD account, try as I might, I'm unable to un-register it:
Can anyone help?
Regards
Dave
Issovits
Jan 04, 2022Aspirant
Hi, i have the same problem, but i got a used one and now it's too old to get support.
Can anyone help me with a workaround ?
- FURRYe38Jan 04, 2022Guru - Experienced User
Something to contact NG support about:
https://my.netgear.com/support/contact.aspx
Can anyone help me with a workaround ? - schumakuJan 04, 2022Guru - Experienced User
Usually a factory reset (-> Nighthawk AC1900 WiFi LTE Modem Router p.176) does remove the ReadyCloud registration all (all?) Netgar routers.
Don't be confused: The product registration (independant of ReadyCloud) can't be removed - just skip that part.
