tlinn
May 28, 2021Aspirant
Unable to upload images from my Canon EOS R5 to the internet through my Nighthawk R7000 (Err 127)
I use a Nighthawk R7000 / AC1900 router. I recently purchased a Canon EOS R5 camera. One of its features is the ability to wirelessly upload photos to Canon's image.canon website. If I tether my came...
michaelkenward
May 29, 2021Guru - Experienced User
I find that Canon's wifi feature isn't the easiest to set up.
Can you connect the camera to the SSID on the R7000?
Is it just to Canon's website? I haven't used that in some time.
Seems to work just fine here. But I have an Orbi router in the middle.
Maybe I'll see what the R7800 and R7000P can do.
What firmware do you have on the R7000?
- tlinnMay 29, 2021Aspirant
Thanks for taking the time to respond, Michael. Your questions are answered in line below.
Yes. I can successfully connect to both the 2.4GHz and 5GHz networks on my R7000.
Yes, though image.canon is the only internet site I have tried to connect to. I am able to wirelessly connect to my HP workstation on my local network using EOS Utility. On the R5, this is a different setting in the Wi-Fi/Bluetooth connection menu ("Upload to Web service" vs "Remote Control (EOS Utility)").
Interestingly, I am able to connect my R5 to image.canon using my iPhone X's wifi hotspot. I had originally assumed this was because I was bypassing the R7000, but after further consideration I realize that my iPhone has been connected to my wifi network while tethering so the R5 was still accessing the internet through the R7000 using the iPhone X as an intermediary.
V1.0.9.88_10.2.88
I don't know if this is a solution so much as it is a workaround. I discovered that connecting to my R7000's guest network instead of using my normal login, the R5 connects immediately and works as expected. I don't know why this makes a difference. If anyone has an explanation I would be interested. When it comes to router configuration, I am pretty ignorant.
