daveooooo's avatar
daveooooo
Initiate
Apr 24, 2019
Unable to use my Nighthawk router as a wireless repeater
I would like to use my Nighthawk router as a wifi repeater. According to a bunch of resources I looked up, Netgear routers usually have a wifi repeater mode. Mine however, does not. It only has Route...
  • daveooooo's avatar
    daveooooo
    Apr 24, 2019
    I thought I put the model number in the first post, but seemingly I did not. That is my mistake. It is a R6700v2. I did notice another post while doing more research on these forums about my model in the meantime, and it seems as though you cannot enable repeating in this model. The posts I was reading earlier were for a different model which I mistook as my model.
    As a side note, for someone who spends a lot of time on these support forums, you sure take a very pompous and rude attitude for helping people. Considering many may not have the technical know-how you have. But thanks anyway.
