SKlinknagel
Jan 01, 2016Aspirant
Unidentified Wifi netwerk: NETGEAR89-Arlo_246968
Hallo. I coudnt find anything inside the forum. So here it goes Installing the new firmware V1.0.6.28_1.1.83 and after activating the Smart Connect functon i have a extra wifi. I cant find it...
- Jan 01, 2016
You should have it under "Basic" settings, If you don't try restarting your router...
You can then disable the Arlo network.
R7KFan
Jan 01, 2016Star
- SKlinknagelJan 01, 2016Aspirant
Oke! Thx
The solution was to change over the settings to Englis. It doesnt show in the Ducth (netherlands) langues.
