SKlinknagel
Jan 01, 2016Aspirant
Unidentified Wifi netwerk: NETGEAR89-Arlo_246968
Hallo. I coudnt find anything inside the forum. So here it goes Installing the new firmware V1.0.6.28_1.1.83 and after activating the Smart Connect functon i have a extra wifi. I cant find it...
- Jan 01, 2016
You should have it under "Basic" settings, If you don't try restarting your router...
You can then disable the Arlo network.
R7KFan
Jan 01, 2016Star
SKlinknagel
Oke! Thx
The solution was to change over the settings to Englis. It doesnt show in the Ducth (netherlands) langues.
