akak
Jun 01, 2018Tutor
Unknown Error 109 during Firmware Update
Current Firmware: 1.0.9.26_10.2.31
In attempting to get the latest Firmware Update 1.0.9.28_10.2.32, after accepting "Yes" to start the update it begins to start downloading... Then within 3 se...
- Jun 06, 2018
Hi akak and jcd1126,
I tested it in our laboratory and was not able to reproduce the error. I have successfully updated the firmware from 1.0.9.26_10.2.31 to 1.0.9.28_10.2.32. I updated it using the check button in the router web interface and also tried the manual update. The browser I used is Chrome.
How did you update the firmware?
I suggest to manually update the firmware. Here's the reference link:
There is also Hot Fix firmware available. I recommend to update the firmware to the latest version.
https://kb.netgear.com/000057097/R7000-Firmware-Version-1-0-9-30-Hot-Fix
Blanca
Community Team
jcd1126
Jun 01, 2018Aspirant
Trying to update firmware. Keep getting error code 109. (Same problem as above.)
antinode
Jun 01, 2018Guru
> Unknown Error: 109
Normally I prefer plain text, but that's strange enough that a
picture might be interesting.
> [...] Keep getting error code 109.
If it's repeatable (inescapable?), then it may be time to try the
TFTP recovery scheme:
https://community.netgear.com/t5/x/x/m-p/1533866#M87578
