akak's avatar
akak
Tutor
Jun 01, 2018
Unknown Error 109 during Firmware Update
Current Firmware: 1.0.9.26_10.2.31   In attempting to get the latest Firmware Update 1.0.9.28_10.2.32, after accepting "Yes" to start the update it begins to start downloading... Then within 3 se...
  • Blanca_O's avatar
    Blanca_O
    Jun 06, 2018
    Hi akak and jcd1126,
    I tested it in our laboratory and was not able to reproduce the error. I have successfully updated the firmware from 1.0.9.26_10.2.31 to 1.0.9.28_10.2.32. I updated it using the check button in the router web interface and also tried the manual update. The browser I used is Chrome.
    How did you update the firmware?
    I suggest to manually update the firmware. Here's the reference link:
    https://kb.netgear.com/23960/
    There is also Hot Fix firmware available. I recommend to update the firmware to the latest version.
    https://kb.netgear.com/000057097/R7000-Firmware-Version-1-0-9-30-Hot-Fix
    Blanca
    Community Team
