Bubbajenni
Dec 25, 2021Aspirant
Unknown MAC address device connected to hotspot
Can anyone identify the device or what is connecting to my personal hotspot and using my data please? The MAC address is;
96:9b:29:aa:ca:af
96:9b:29:aa:ca:af
Check the address, I didn't find anything.
A typical random MAC address - used for example by default on Apple mobile devices, Android mobiles, except when you configure the connection (by SSID) to use the hardware. Very probably your very on device - who else knows the SSID and the matching security key? Say "thank you Apple & Co" for the most **** idea ever for privacy.
96:9b:29...
The quick synopsis is look at the second character in a MAC address, if it is a 2, 6, A, or E it is a randomized address.
- BubbajenniAspirantSorry to sound silly but I’m not very tech savvy, what do you mean by my own device?
In a sense how am I connected to my own hotspot and using my own data, I thought this only happened if I say used my hotspot for internet on another device (say an iPad which had no internet)?.- schumakuGuru - Experienced User
Yes, an iPad as well as your iPhone are good good examples. Check the Settings -> Wifi -> (your router wireless name) -> --- there is e.g a Auto-Join and next ot it a Private Address control which is ba default enabled (disabling it does lead to a Privacy Warning - on your very own hotspot router, what a nonsense). Before disabling is, scroll up, there you see the "Wi-Fi Address" ... that's most likely one of these you are hunting. Disable it and be happy.
- BubbajenniAspirantThe device is an IPhone XR.
I have no clue about SSID’s, what does it mean about configuring? I don’t think I’ve changed any settings I know of?.
