cvanzante
Oct 22, 2021Tutor
unknown network
Hello. After a failed firmware update, I successfully reset my R7000 and it now shows my firmware using V1.0.11.126 but it said no need for update at setup. Using the Nighthawk app on my iPhone, I ...
- Oct 27, 2021
I am responding to my own earlier post. After doing some additional online research, I came across an individual who mentioned a 'sleeping' Kindle. I put mine on a different network and the phantom unknown device on my network disappeared.
Oct 22, 2021Guru - Experienced User
Try a reset on the router again by pressing the reset button for 10 seconds then release. Connect 1 wired PC to the router and use a web browser pointed at 192.168.1.1 to setup the router from scratch.
cvanzante
Oct 22, 2021Tutor
Thanks for the reply Furry. My PCs lack ethernet ports and I wonder if the HDMI port would work. If I am unable to accomplish this task, am I OK with just leaving that network disabled? I am more interested in security than resolving the mystery. Thanks again.
