cvanzante
Oct 22, 2021Tutor
unknown network
Hello. After a failed firmware update, I successfully reset my R7000 and it now shows my firmware using V1.0.11.126 but it said no need for update at setup. Using the Nighthawk app on my iPhone, I ...
- Oct 27, 2021
I am responding to my own earlier post. After doing some additional online research, I came across an individual who mentioned a 'sleeping' Kindle. I put mine on a different network and the phantom unknown device on my network disappeared.
cvanzante
Oct 27, 2021Tutor
Oct 27, 2021Guru - Experienced User
Sounds like you found the cause.
For PCs with no ethernet abilities, you can install a USB to ethernet adapter on theses PCs.
Please mark your thread as solved so other will know.
Enjoy.
