ArneH
Jan 14, 2021Tutor
Unstable after firmware update
I have an R8000 with firmware V1.0.4.68, this is slightly better than 1.0.4.66 and it is here where problem begin After update to 1.0.4.66 5GHz-2 did not work according to the red sign. (But it seem...
ArneH
Feb 01, 2021Tutor
Hej
Now have downgrade to V18! Then it is stable and don’t buffer videos, telephone’s etc.
Wife also happy 😊.
But I guess its ton of update that it an improvement especially in the security area.
Feb 01, 2021Guru - Experienced User
the .28 is a pretty solid version and has a few bug/product fixes. The newer versions got the netgear armor upgrade and that's when it seemed to cause issues
- ArneHFeb 01, 2021Tutor
I always update the router so I thought that had at least V58. But when reinstalled V58 the problem still was there. And I used the 5G for a bridge application. But V28 merge all three band to one single (smart connect). Little confused because as I remember it I had V58.
Waiting for the next version, and testing then.
And never has used the armor feature
- plemansFeb 01, 2021Guru - Experienced User
Even if you don't use armor, its still built into the firmware on versions newer than the .28 version.
A small portion of routers have issues with the armor and those people I usually refer to the .28.
Best bet if you do update?
factory reset
then install the firmware over a hardwired connection
then factory reset 1 more time and do a clean install (not from backups)
that seems to work for some with the newer version issue.
Thank's, I do that when next update comming :)
