ArneH
Jan 14, 2021Tutor
Unstable after firmware update
I have an R8000 with firmware V1.0.4.68, this is slightly better than 1.0.4.66 and it is here where problem begin After update to 1.0.4.66 5GHz-2 did not work according to the red sign. (But it seem...
Feb 01, 2021Guru - Experienced User
the .28 is a pretty solid version and has a few bug/product fixes. The newer versions got the netgear armor upgrade and that's when it seemed to cause issues
ArneH
Feb 01, 2021Tutor
I always update the router so I thought that had at least V58. But when reinstalled V58 the problem still was there. And I used the 5G for a bridge application. But V28 merge all three band to one single (smart connect). Little confused because as I remember it I had V58.
Waiting for the next version, and testing then.
And never has used the armor feature
- plemansFeb 01, 2021Guru - Experienced User
Even if you don't use armor, its still built into the firmware on versions newer than the .28 version.
A small portion of routers have issues with the armor and those people I usually refer to the .28.
Best bet if you do update?
factory reset
then install the firmware over a hardwired connection
then factory reset 1 more time and do a clean install (not from backups)
that seems to work for some with the newer version issue.
- ArneHFeb 01, 2021Tutor
Thank's, I do that when next update comming :)
