eddym
Nov 06, 2021Tutor
Update and NAT type with my N600 Wireless Dual Band Router
Hey, so i have the N600 Wireless Dual Band Router and im having a ton of issues. I dont know if it needs an update or the nat type fixed but i do not have my routerlogin.net password and username so ...
Nov 06, 2021Guru - Experienced User
What actual router do you have? N600 is a speed.
If you're a professional gamer, you really should update. The N600 devices are several generations and way behind on speeds.
What modem/gateway is the router connected to?
