eddym
Nov 06, 2021Tutor
Update and NAT type with my N600 Wireless Dual Band Router
Hey, so i have the N600 Wireless Dual Band Router and im having a ton of issues. I dont know if it needs an update or the nat type fixed but i do not have my routerlogin.net password and username so ...
eddym
Nov 06, 2021Tutor
WNDR3400v3 And it’s just connected to a Ubiquiti Networks Nanostation loco M5 that gets its signal shot across the property to here. And yeah I’m looking at a better router to upgrade to but budget is tight right now because I had to buy some equipment
Nov 06, 2021Guru - Experienced User
A point to point system is going to add latency and slow speeds.
Try it with your gaming device directly connected to the nanostation. See what performance you get directly from it.
- eddymNov 06, 2021TutorI tried that earlier today in fact and it lowered the frequency of my lag spikes but made my NAT type “strict”
- plemansNov 06, 2021Guru - Experienced User
so you're limited by the system that's providing your connection.
If whats supplying you is slowing your speed and causing the nat, nothing you add on the end of it is going to change that as they're controlling NAT/latency/etc.
- eddymNov 06, 2021TutorOkay well. There’s also where 2-5am the ping is a steady 50ping and reliable. So. I don’t understand why at that time it’s basically the internet I want and the rest of the day is just pretty bad. Do you know why it’s like that or how I could fix it to the rest of the day it’s like that?
