eddym
Nov 06, 2021Tutor
Update and NAT type with my N600 Wireless Dual Band Router
Hey, so i have the N600 Wireless Dual Band Router and im having a ton of issues. I dont know if it needs an update or the nat type fixed but i do not have my routerlogin.net password and username so ...
Nov 06, 2021Guru - Experienced User
whats supplying your nanostation?
You need to test for 24 hours off that. If you're getting the ping increases while directly connected to that, its whats supplying your system.
If the nanostation by itself is fine, then you can look at seeing if its a double nat issue
eddym
Nov 06, 2021Tutor
My Xbox says double nat. How do I fix that. What is it?
- plemansNov 07, 2021Guru - Experienced User
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options if you can. Yours is a bit more complicated because you haven't put the setup before the ubiquiti nano.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
