eddym
Nov 07, 2021Tutor
Update and NAT type with my N600 Wireless Dual Band Router
Hey, so i have the N600 Wireless Dual Band Router and im having a ton of issues. I dont know if it needs an update or the nat type fixed but i do not have my routerlogin.net password and username so ...
eddym
Nov 07, 2021Tutor
My Xbox says double nat. How do I fix that. What is it?
Nov 07, 2021Guru - Experienced User
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options if you can. Yours is a bit more complicated because you haven't put the setup before the ubiquiti nano.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
