lmfao
Apr 15, 2024Aspirant
Update Firmware Router in AP Mode (R7800)
My router is in AP mode and I want to be able to login to it, change the wifi network info and update the firmware. However, I can't login to it and the app can't find it on the network.
- Apr 15, 2024
lmfao wrote:My router is in AP mode and I want to be able to login to it, change the wifi network info and update the firmware. However, I can't login to it and the app can't find it on the network.
Avoid the mobile application. It is of no use in this situation.
Your R7800 AP is connected to an upstream router. Log in to that router, go to connected devices and find out the IP address that is assigned to your R7800. Use that IP address in the address bar on your web browser. Hit enter and you should be at the login page for the R7800 user interface.
Once in the user interface, you can manually update the firmware on the R7800.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Kitsap
Apr 15, 2024Master
lmfao
Tried that before posting, didn't work. The IP address doesn't respond/open up with the web interface.
- KitsapApr 15, 2024Master
lmfao wrote:Tried that before posting, didn't work. The IP address doesn't respond/open up with the web interface.
Did you clear the cache on the web browser you are using?
Did you try a different web browser?
Are you working with iOS or Windows?
Can you successfully connect to the Wi-Fi broadcast?
This may help: https://kb.netgear.com/000064389/How-do-I-find-the-IP-address-of-my-NETGEAR-wireless-access-point
