lmfao
Apr 15, 2024Aspirant
Update Firmware Router in AP Mode (R7800)
My router is in AP mode and I want to be able to login to it, change the wifi network info and update the firmware. However, I can't login to it and the app can't find it on the network.
- Apr 15, 2024
lmfao wrote:My router is in AP mode and I want to be able to login to it, change the wifi network info and update the firmware. However, I can't login to it and the app can't find it on the network.
Avoid the mobile application. It is of no use in this situation.
Your R7800 AP is connected to an upstream router. Log in to that router, go to connected devices and find out the IP address that is assigned to your R7800. Use that IP address in the address bar on your web browser. Hit enter and you should be at the login page for the R7800 user interface.
Once in the user interface, you can manually update the firmware on the R7800.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Kitsap
Apr 15, 2024Master
lmfao
Apr 16, 2024Aspirant
OK this actually worked, I wasn't aware the IP address changed in the time that I took it from the upstream router and the five minutes later when I put it into the browser. Literally no reason why the DHCP renew happened (no reboot/etc.) but for some reason it did lol.
- FURRYe38Apr 16, 2024Guru - Experienced User
One can set the R7800 in AP mode using a Static IP address configuration so you know what the IP address is that doesn't change. i.e. 192.168.1.78. Something I do with mine.
Glad you got it.
- KitsapApr 16, 2024Master
lmfao wrote:OK this actually worked, I wasn't aware the IP address changed in the time that I took it from the upstream router and the five minutes later when I put it into the browser. Literally no reason why the DHCP renew happened (no reboot/etc.) but for some reason it did lol.
For consumer routers, the IP addresses that are assigned by DHCP renew every 24 hours.
Solid recommendation from FURRYe38, configure your access point with a static IP address. It stays put and you can bookmark it in your web browser.
Glad you got it solved.
- michaelkenwardApr 17, 2024Guru - Experienced User
Kitsap wrote:Solid recommendation from FURRYe38, configure your access point with a static IP address. It stays put and you can bookmark it in your web browser.
An alternative is not to fix the IP address on the AP but to reserve it on the router.
I have used both.
It is a matter of choice and how you like to manage your network.
Address Reservation can be easier to manage if you have dozens of devices to handle individually.
- Advanced
- Setup
- LAN Setup
- Address Reservation
- Add
You could almost say "one place fix all".
