CLAIREWp3
Sep 09, 2021Tutor
update V1.0.5.36
Our router constantly stays on 60GHZ since the update and the router is constantly restarting since the update - nothing shows on the logs so it can only be the update as we had no issues before upda...
- Sep 10, 2021Thank you, the downgrade (down to the previous version) worked last night and had no issues since.
Sep 09, 2021Guru - Experienced User
Have you tried a factory reset and reinstall?
Or tried downgrading the firmware?
- CLAIREWp3Sep 09, 2021Tutor
I looked online and could only find V1.1.0.18 - tried installing that and what a mess it really did not like it, gave me constant "trying to configure" window.
I would prefer not to factory reset
- plemansSep 09, 2021Guru - Experienced User
Not sure where you were looking but you can get the current and all the older firmwares on the support site.
https://www.netgear.com/support/product/R9000.aspx
best steps for downgrading?
- download the version you want
- extract it
- manually connect a pc/laptop to your router (disable the pc/laptops wifi)
- follow the manual firmware update process but use the firmware you downloaded
- *optional but recommended* factory reset the router and reinstall.
