CLAIREWp3
Sep 09, 2021Tutor
update V1.0.5.36
Our router constantly stays on 60GHZ since the update and the router is constantly restarting since the update - nothing shows on the logs so it can only be the update as we had no issues before upda...
- Sep 10, 2021Thank you, the downgrade (down to the previous version) worked last night and had no issues since.
CLAIREWp3
Sep 09, 2021Tutor
I looked online and could only find V1.1.0.18 - tried installing that and what a mess it really did not like it, gave me constant "trying to configure" window.
I would prefer not to factory reset
Sep 09, 2021Guru - Experienced User
Not sure where you were looking but you can get the current and all the older firmwares on the support site.
https://www.netgear.com/support/product/R9000.aspx
