CLAIREWp3
Sep 09, 2021Tutor
update V1.0.5.36
Our router constantly stays on 60GHZ since the update and the router is constantly restarting since the update - nothing shows on the logs so it can only be the update as we had no issues before upda...
- Sep 10, 2021Thank you, the downgrade (down to the previous version) worked last night and had no issues since.
Sep 09, 2021Guru - Experienced User
- download the version you want
- extract it
- manually connect a pc/laptop to your router (disable the pc/laptops wifi)
- follow the manual firmware update process but use the firmware you downloaded
- *optional but recommended* factory reset the router and reinstall.
