Rbooe05
Jul 13, 2017Aspirant
Updated firmware now server dns address could not be found
I updated the firmware on my nighthawk router and I use the dynamic DNS program as well as port forwarding for my cameras. After the update I get a random error when connecting to any websites. It rea...
- Jul 17, 2017
I actually ended up resetting the router by holding the reset for 10 seconds. Then i set up my networks and my port forwarding again and i went the backup screen and saved my settings to my laptop. Then i upgraded the firmware with the same results. I then went to the backup screen again and i restored all my settings i had saved on my laptop and it rebooted and worked. Not sure whats going on with that but it worked for me! Hope that helps
GearNetRouter
Jul 17, 2017Virtuoso
Did you find a solution? I have an R7000 router, upgraded firmware and installed OpenVPN for Android and have the exact same problem!
Rbooe05
Jul 17, 2017Aspirant
