kpkiernan
Aug 19, 2021Follower
Updated to latest firmware and now buggy connections and Teamviewer won't connect
Have been troubleshooting a general connection issue with our cable company and now that's fixed (modem) but flashed to updated FW 1.0.4.74 On the router and now we have very buggy connection and...
Aug 20, 2021Guru - Experienced User
What modem/gateway is the router connected to?
were you having the issues prior to the firmware update?
anytime theres an issue after a firmware upgrade,I recommend trying a factory reset and reinstall. during the reinstall, don't use a backup configuration.
try that first.
If it doesn't help, then we can try downgrading.
