joelferris
Oct 11, 2016Follower
Updated to Mac OS 10.12 Sierra and now no printer and Genie quits
- Mar 16, 2017
We have officially released the compatible software to work with Mac OSX and above.
ElaineM
Oct 13, 2016NETGEAR Employee Retired
Hi joelferris
Welcome to the community!
Since the release of El Capitan, ReadySHARE Print stopped working because the USB Control Center utility is not compatible to work with it.
Our engineers are still working on the said issue. Anyhow, let me check with our engineering team about the new OS. For the meantime, you may want to use Bonjour service for your printing needs.
likessailboats
Nov 01, 2016Tutor
Was using Bonjour option as a work-around to at least use my printer attached to the R7000 USB port. Upgraded to macOS Sierra 10.12.1 and the Bonjour option no longer works (printer not seen when adding). Yes, Readyshare has been broken on Mac since "El Capitain". Please fix. Thanks.
John
- likessailboatsNov 06, 2016Tutor
Earlier I posted that the Bonjour solution no longer worked with macOS Sierra. I just now tried again and was successful. No clue what changed.
Would still like full functionality for both USB ports on the R7000 with macOS Sierra. Thanks.
- ElaineMNov 30, 2016NETGEAR Employee Retired
Hello All, I am still waiting from our engineering team an update about the USB Center Control Utility that will be compatible with your Mac OS.
It's still under SQA, once it has passed that phase I will let you all know.
- Buckeye74Jan 29, 2017Aspirant
solution yet for 10.12 Sierra?
