Mames
Oct 17, 2022Follower
Updates or hacks, Jumbo Frames on R9000 x10?
Hi I just switched two Synology servers, two Macs, and my Netgear managed switch GS724T (all wired) over to Jumbo Frames (9000 MTU) then was a tiny bit shocked to find that my X10 R9000 router seems t...
Oct 17, 2022Guru - Experienced User
Most NGs home class routers support MTU 1500 only over the WAN and LAN side I believe as this is the norm and standard for home router networking. Beyond that, I would check the user manual for jumbo frame support. If you don't see any references to that in the manual then it would not be supported.
