vmhoffers
Sep 23, 2021Aspirant
Updating Firmware R6400 v2
UPDATED: While I was awaiting a response, I decided to try logging out of the 192.168... and log back in and start all over again using the downloaded firmware. I worked this time. Hope this helps...
vmhoffers
I put the model number in the text of the message since I could not find it in the drop down list of options. ". Nighthawk AC 1750 R6400 v2"
I DID follow the instructions in the manual as indicated in the text of the original message (2nd attempt), which was unsuccessful.
As I mentioned, logging off and restarting the whole process allowed the update to happen successfully though I am not sure why.
Thank you
Sep 23, 2021Guru - Experienced User
Thats just a tag that gets included with your post so users know what model NG product you have. Does not direct your post to specific router model forums.
Hopefully someone in that forum will be able to help out.
Also review NG download page for your model router and any FW update help there including the user manual.
Good Luck.
