Riceburner1's avatar
Riceburner1
Follower
Jul 08, 2024
upgrade from my r7000 ac1900 to a newer router
I am currently using a Netgear Nighthawk R7000 Smart WiFi Router Ac1900. I have 2 PC's, 2 phones, 3 wireless battery operated cameras. We stream some movies with little or no problems via Hoopla. My ...
  • FURRYe38's avatar
    Jul 08, 2024
    Most likely no. At that range and distances, any wifi signal will be very weak if at all even connectable.
    You'll need to get maybe into a wifi bridge that can get signal in between two points for that distance or put in some STP LAN cabling and put in a wired wireless AP at the remote location.
